Tranny Question
GSX'er587
183
May 9, 2004
Novi, Michigan
Ok, so i was driving then out of nowherer my car will no longer go into 2nd or 4th gear. It doesnt frind or anything it just feels really really loose and wont go into those 2 gears. Doesn anyone have any ideas on what this could be??
Check you shifter linkage under the hood. There should be a little play but nothing out of the ordinary. Also make shure that you can shift by hand into all gears 1 through reverse. If you can that means that your shifter linkage is going or gone bad.
Rich
92awddsm said:
Did anyone understand this? :confused:
Also check the shifter itself and the linkage under the console. Can you shift it into all gears when the car is not running?
I did!
I have one Im trying to get rid of!!!!!!!!!
Im gonna go look at my linkage cables but i might need that tranny so if you could fill me in on it id be helpful. Thanks
Good news, it turned out to be the linkage cable and now that its tightened down its shifting better than ever :thumb: Thanks for the help guys
:dsm:
  • Wanted 2g ISO Rear Pass EDM Tail light
    Looking for only a passenger rear EDM tail light for my 2g. Please lmk if you have one lying...
    • Gabriel Pena
  • Wanted 4G63 ISO built short block
    Looking for either a 7 bolt split thrust or 6 bolt
    • Gabriel Pena
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale 2g 1996 Eagle Talon TSI AWD
    I have a 96 Eagle Talon AWD standard tranny for sale. The car still ran when I parked it. I had...
    • eli1977
  • For sale 2g 2g front strut shock cup. MR103156. New.
    Mitsubishi Oem # MR103156 front suspension strut cup. New. Message 702-741-6987.
