kyle h.
- 160
- 1
- Apr 2, 2002
etown,
Pennsylvania
well so far i've checked everything on my car. I've used the factory mitsu/chrysler manual and checked everything it tells you to check for causes of a rough idle.
what i've come up with:
-tb shaft seal leaking
-intercooler has holes in the one pipe (fixed with duct tape)
-car boosts 17psi when its cool out and 16 decreasing to 14 when its hot out, holds 17 fine when its cool tho.
very rough idle, 10 inHg, sounds like a miss, but all wires seem to be getting spark, i do need a new set of wires tho, #4 tested bad, but still gets spark through it.
this car is getting to be frustrating trying to fix it and everything i do doesnt seem to do the trick.
when i taped the intercooler up it made it idle the slightest bit better. i also replaced the ISC and it doesnt stall anymore.
it sounds like i have a leak around my leak tester. im starting to think it might be the turbo seals, on the compressor.
will those little of leaks cause the car to idle like its got a huge vacuum/boost leak?
i'm trying to tune the thing and i can get the o2 trim to settle around zero (for low throttle), but i can't get the low fuel trim to come down from 139. i replaced the o2 sensor and the low trim was at 100 for a while, and i got way better gas mileage. now it went back up to 139 and i get much much worse gas mileage. my mid and high trim were in the 80's, and for some reason they've come back around 100.
can it be the weather that is making my car change so much in the fuel trims? it's been fairly hot lately.
mods include:
3" intake w/ 1g mas (soon to be 2g mas) & 1g k&n filter
2.5" exhaust from the o2 housing back (no cat)
my fuel pressure seems fine and all the injectors seem to be operating fine as well.
do you guys think its the small vacuum leaks that make my car idle around 10 inHg and very lumpy, like i've got a miss. everyone tells me i've got a miss, but i'm 100% sure i don't, because the car screams like a raped date when its not idling.
sorry for the long post, but i dunno what to do. can't wait until i have enough money to fix my honda
mods include:
