genzaroff
- Jul 20, 2004
Oak Harbor,
Washington
Here's the deal, I helped my buddy do a tranny swap on his 92 Talon 2.0L non-turbo with a 5 speed and the swap actually went rather well. From the start we noticed a few little things different about the two transmission units like the tranny mount point had one bolt hole higher then the other compared to the transmission that was origionally in the car.
The breakdown of the problem is as follows: when turning the key the starter sounds like it's skipping over the flywheel ring gear and only makes a grinding noise. We removed the starter and bench tested it and the unit worked fine. The pinion gear on the starter shows no abnormal wear and the ring gear on the flywheel is fine as well. We've removed and installed the starter several times but we're at a loss on this one. If anyone can help please do!
What?
