Problem shifting gears!!
NoelTalon
Jun 22, 2004
Puerto Rico, Central America
Hi everyone, new to this forum...
I'm having problems shifting from 1 to 2 gear.. when i'm running the car at full boost and hard rev., I try to shift from 1 to 2, the trans dont release the 1 gear.. At low speed I can shift without problems..
the clutch and slave pumps looks in great shape, the shifting cables are almost new.. i'm using act 2900 clutch with act flywheel..
thanks for your help..
Ouch a 2900?I hope that isnt a street car, i think they only recommend that for strip cars. Someone correct me if im wrong but i think that size of clutch isnt good for a street car...can you shift through the rest of the gears fine?(at high rpm)
when u installed clutch did u put a slave clyinder extenstion rod in i had same problem and try bleeding ## clutch
