Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum > Problem Diagnosis
Problem Diagnosis Can't figure out the problem? Does the question not fit in one of the other tech forums? New Members can post here.
Reply
LinkBack Thread Tools
Old 06-10-2004, 03:15 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: UndergroundR32 is an unknown
High o2 trim and fuel trim doesn't make sense
My o2 trims are always above 100% whenever I'm idling. I richen up my 1k fuel correction settings to as much as 0% and it still reads high, and I have 720's. Also, my low fuel trim goes up as high as 118% and stays there. My other fuel trims are fine, and every rpm setting is set at -28% besides my 1k correction settings. Also, my wideband reads very lean at idle. In the 20:1 a/f ratios. I thought that maybe my oem o2 sensor wasn't reading right, until I used the wideband and it read lean as well. Any ideas? It seems that it would make no sense for any car to be running lean at idle, even with correction settings at 0% with injectors of this size.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 07-21-2004, 03:50 PM   #2 (permalink)
Proven Member
Reputation: kyle h. is an unknown
do you have a vacuum leak? or possibly a leak before the turbo (intake 'leak')
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.08741903 seconds (66.01% PHP - 33.99% MySQL) with 9 queries
