1fastRS
- 79
- Dec 17, 2003
Columbus,
Ohio
heres my problem, i put on a 3" cat back w/ a high flow cat. i also have a header. after driving the car for about 2 minutes my cel came on. i put out these codes:
PO138 - downstream heated O2 sensor fault (bank 1) <------ have no idea what bank 1 is.
PO139 - downstream O2 sensor stays at center
PO141 - downstream heated O2 sensor heater circut fault (bank 1)
what the hell does this mean? is my O2 sensor bad? can i use a O2 simulator and fix the problem or what. also out of no where my car has a horrible idle (goes back and forth from 800-600rpm) and when i drive it pops almost like a back fire but not as bad until about 3k, and then smooths out. while it does this it loses power. also if i'm driving and i upshift (ex. 4 to 3) if pops, and stalls before it goes. also if i'm crusing below 3k and i hit the gas it does the pop and stall thing.
what the hell is it!
i've been told that i'm running too lean. could this be from the O2 sensor? what else could cause it? i just changed my plugs today, and i'm changing the fuel filter and wires this week. please give me some other suggestions.
