idle
tsidrift1
819
5
May 12, 2004
Decatur, Illinois
i have two questions. one is my car has a high idle to it and when i drive it around it is fine and then when i push in the clutch to come to a stop, the idle should go down but it stays at 2 rpms for awhile and then goes down to one. the second problem i have is my car chatters when i shift into first and when i shift into second. i have had this with every dsm ive owned.(the chatter problem).
i have a 95 talon esi and have had that same problem with the revs coming down. unfourtunately I am still looking for a solution myself. So far I no it is not my throttle. I verified that it closes fully
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
