RandyJr
- 97
- May 15, 2004
Moss Point,
Mississippi
Just fixed my 1992's headgasket and I have another bad problem with it. After doing a search, it seems that plugs and wires would be the main problem of slow acceleration and hesitiation.
I have installed brand new NGK plugs and wires, new fuel filter, correct timing belt and iginiton timing, and my aftermarket boost gauge shows the boost to hold steady the whole time I have the gas pedal floored. That leads me to believe that there are no boost leaks if the boost spikes and holds steady.
The slow accelerating and minor hestitation seems to happen as the rpms go up. My low end seems good, it's about at 3,000 rpms or around that, the car just does not speed up. I am not hitting fuel cut at all and no CEL. I took the car to about 6000 rpms on the highway and it seems like the faster it got, the slower the rpms went up. It almost stopped accelerating at about 6,000 and would not go higher, I had to shift to speed up.
When I get on it in any gear and at any speed, the boost shoots up really fast with very slow acceleration. I can hear the turbo spinning and the BOV working. It almost seems like the exhaust is super restrictive. I will be going to drop the exhaust pipe and take it for a run just for the heck of it. It seems like I can't beat a n/t from a stop and this is an AWD!!! That shows how slow it is once I give it a lot of gas and it begins to try and speed up.
I really need some advice on where to start, I'll report back after I drop the exhaust. Maybe a clogged cat convertor. If anyone has anything to add, please do.
. are clogged cat's a somewhat common problem?
