help!!!!!!!!
boostcrazy92tsi
125
Aug 3, 2003
ok so my thermal valve or ported vaccum switch is busted. its leakin in one spot and one of the line nipples broke off. local parts stores dont carry it and the dealers arent open till tuesday. can i cap the lines or run them together and bypass the valve???? i know that it operates the evap at low temps. i need a quick fix!!!!!
:talon:
Im not sure on that one, but I had to ask: Are you daily driving a 90 Talon TSi AWD? OMG
boostcrazy92tsi said:
You better believe it... all day everyday. Why wouldnt I? Anyway I need help, please!
Why wouldnt you? Put it to you like this: When I find an AWD TSi and build it a bit ;) , it wont be...practical to drive every day. Plus, why would you want to jack up the miles on an already finicky car by putting to and from work? Not to mention risking fender-benders etc.
Mine (if EVER I find one) will be streetable enough just to drive to the track or dyno and back, and to spank ricers and/or domestictards on the weekends. :thumb:
tryin to keep on topic here guys...... wisemen or someone with some more experience then please help me out here!! can i loop them together or cap them off?????
:talon:
i bought it to drive it... no reason to sink money into a car and let it sit around until i have time to goto the track. plus its fun as hell to drive and i destroy the ricers whenever i get the chance..
absolutely....they are an emissions item and you can run fine without them ever being there....so you can eliminate them, plug them together, or cap them off, does'nt matter to the car, it could care less...........i also drive a 90 gsx for a daily work beater it had 89,000 on it last year when the rear end exploded and then i just yanked the drive shaft and rear axles and drive it as a fwd every day........bwahaahaa... :dsm:
k thanks thats what i thought. ill prolly just loop them together until i can get the new part this week.
LOL my car only has 43k on it so i got another 43k to go before i transform mine into a fwd :p
