nestamon99
- 41
- May 10, 2004
Sunriver,
Oregon
Hi guys and gals...I am new to DSMs and I need your help and this club. I bought an eagle talon tsi awd for real cheap. I couldn't pass the opportunity. When I drove the vehicle for the first time, the turbo worked. Then about 30 miles later my fun was taken away from me. The turbo decided to stop spooling. I figured my turbo was bad, so I check the shaft play and there's none. It's very surprising because this car has 200k miles. The guy who I bought it from didn't know much about the vehicle. I do know he replaced the knock sensor with a used one. I don't think it would stop the turbo from spooling though!!??? I can hear the turbo whining up but no boost. So I checked my wastegate and thinking that it was bad, I replaced it with one my brother had laying around from another eagle talon. Nothing. I checked vaccuum from every hose connected to the wastegate. I even pulled on the rod of the wastegate and used my thumb to block all the air it sucked in. Then I moved my finger from the nipple on the wastegate and air was released. So I know the nipple is not clogged. I installed washers between the turbo and the wastegate bracket to close the wastegate shut. Nothing, no boost. Then I checked the blow off valve to see if it was not working and maybe leaking all that air. Nope. No air coming out while the engine is revving. So, I replaced the MAS with my brothers. I know this one is working but nothing. No BOOST still. Seeing my brother's car and riding in it with lots of boost makes me really mad. Need some input guys.
