sphinx0nine
- 99
- Nov 13, 2003
Calgary,
yesterday before goin to the track.. i re threaded a bolt on the left side of the exhaust manifod.
I shorted the alternator, but i didnt think it was gonna die.
So the car worked fine.. but there was something kinda strage, the deck will go off when i pushed the break..
none of the fuses are bad..
but the battery is staying at 11.59 v.
any ideas..
any ideas..
History: Never had any problems at all, then one say the alternator died (killed the battery too) about...6 months ago. I got a new alternator and battery, and didnt have any problems until about a month ago. ALL of my lights (interior, dash, headlights, etc) fade in and out, but at a relative speed to my RPM's. At idle, no fading...I noticed the engine power fades in and out too at lower speeds and feels really jerky. Also, at almost exactly 4000 RPM there is a loud chirping sort of noise coming from somewhere in/near the engine, but it doesnt happen at 3900 or 4100, just 4000. Anyone know what the problem is?
.... But I went back to the car after about 20 min cause my all my hazard lights and all the lights and stuff in the car had gone out so i assumed my battery was grounding out somewhere. I disconnected the battery and looked through and through, and what happened was the wires from the battery/alternater to the fuse box was scraping against the metal piece that held the stock IC pipes down. And there was a metal rod from that metal piece to my tranny. I killed the master and slave cylinders and my tranny was due for a rebuild anyway. But all i did was wrap some electrical tape around the wires again and the car started up just fine. So I would suggest looking at any big clusters of wire and if you don't know what burning wire smells like, take some spare wire and burn it... then start you car and see if you smell any wire burnin up in ur engine, its a distinct smell but i really can't describe it. GOOD LUCK!
