clutch question
Killa95GS-X
126
Oct 29, 2003
sacramento, California
i was wondering if there is like a seal or something on the firewall on my 95 gsx were my clutch goes through. cause there is fluid leakking slowly out i have to add brake fluid all the time and i wondered if it could be a seal?thanks
nick :dsm:
Same thing happened to me on my last Talon. Check the hydrolic lines leading into the tranny if its tightened in there crooked it will cause a slow leak. If that isnt it let me know
there is a thin gasket between the master cylinder and the firewall, Im not 100% sure if fluid can leak from that gasket. Your best bet is to start at the master cylinder and just follow the hydraulic line all the way to the slave cylinder.
ok thanks guys i am going to check it out more today cause it is leacking all over my floor board and my pedal is so soft now. so to fix it i should get the whole slave cylinder? thanks i really appreciate the help.
nick
nick
Its not the slave cylinder, thats located by the tranny, it wouldn't leak into the car. Like defiant said its probably the master cylinder.
No. Gibberish. Thank you for playing, but you don't win this lovely dinette set, picked out just for you.
Please review how a master cylinder works and what's inside it before further burrowing into the peat.
:rolleyes:
oops i ment master not slave sorry sorry about that i was in a hurry. thanks for the help.
nick
nick
Yea thats what I thought but I didn't want u buying the wrong part just in case ;) Good luck!
  • Wanted 2g Ac tensioner
    Looking for ac tensioner and pulley for 2g
    • Simo_217
    • 92AWDHX40
    • eclipsemf
