HOOKSH
- 194
- May 8, 2003
Venice,
installed new UICP with HKS SSQV about a month ago, and was running 14b @ 8psi. was running great, really smooth, good pull for only 8psi, no problems at all. so i turned it up to 14psi, pulled pretty hard, but at about 4500-5000 it started bucking, but it isnt fuel cut because it keeps on pulling through it. i had a CEL a few months back P0400 i think, EGR flow fault. so i was planning on getting the EGR valve checked, but then the CEL went away, and i wasnt having any problems so i didnt bother with that. if i go about 80% throttle, probably about 10-12psi, it pulls really hard, and runs PERFECTLY smooth, no issues at all. any ideas? im gonna check for IC leaks tonight, but if 8psi runs perfect, i dont think itll be that. MAS should be in good shape. the only thing i can think of is either a bad EGR valve, or possibly a bad TPS. plugs and wires are both brand new, and didnt help at all, went with NGK BPR6ES plugs gapped to .028" any help would be great, sorry about being longwinded, but im just stressin it cuz im trying to sell the car, and i looked thru about 5 pages of a search on bucking and found so many diff things i didnt know where to start. somebody please help me
