prlem help!!!
x3jj3x
Feb 28, 2004
oglesby, Illinois
got a 90 gsx bought it and it wasn't running needed to be timed. well i got it timed used a timing light, got new everything for it fluids, belts, spark plugs, getting really hot spark, good compression, tested it. well tried starting it and it wont, tried push starting it and it wants to start so bad, my timing order is 4321, and then on the side is 4123 i think i got everything right but it still wont start. i am thinking it is the ecu right about now. i dont know if any of u have any idears what am i doing wrong then please say so. i will check all the wiring connection right now. and tell me what else i can to do get it started thanx.
i dont know the guy just told me it neeeded timing i only got the car for 150 dollars. wait til i get some pics of it you will see why i got it. the engine bay is so clean and the interior is perfect. it has perfect compression
Are you sure he meant ignition timing and not cam timing? Check out this guide to replace (or just check) your timing belt: http://www.vfaq.com/mods/timingbelt-1G.html
It sounds like your t-belt may be off a couple marks, check it out.
