Scott95GSX
- Jan 7, 2003
Hello,
I'm having trouble with my clutch pedal
A couple of days ago on a road trip it started sticking to the floor in the middle of the drive. I pulled over, checked the fluid level (which was fine) and when I started the car back up again it felt better. After being on the road for a few minutes the clutch started sticking again. Fluid level is still fine and I haven't seen any leaking fluid under the car or on the pedal. Whatever the problem is it seems to get worse the longer the car runs, then magically gets better when I restart it.
I've done the searches and run across all the threads about crankwalk (I don't think it's CW, I have the problem when stopped, not just when turning) and also read the threads about master/slave cylinder problems. Since I haven't seen any leaking fluid it would seem to rule out the master/slave cylinders based on what little I know...
Anyways I'm at a loss what to do, any suggestions?
thanks, Scott
thanks, Scott
