EvolvingGST
- 1,710
- 6
- Jun 24, 2002
Boston,
Massachusetts
OK here is the story...
Well I was driving one day and there was this car that slams on its breaks... so I had to slam on mine... Well after that my car wouldn't shift into first.. everytime I did it would kick me out.. same when I tried to shift it to second. So I shut the car off and restart it and then it worked..
But now when I shift into 1st second or reverse with my clutch fully engaged the car is still shaking and will idle a little lower than it should and the car shakes. So it will drop to like 700 rpm with the clutch fully down. Another symptom that started that day is when i downshift at low RPMs it shakes... not like ultra low RPMS i am not retarded.... Like from 4.5k from 4th to 3rd it will kinda make a noise *clunk* and then it kinda makes that shake thing again... Where as before this incident it didnt happen.
I am thinking fly wheel?
I had my clutch installed at 2002 of september. ACT 2100
but I only had the fly wheel resurfaced.. So I was wondering would that have f*cked my fly wheel up or something along those lines? I am guessing it has something to do with the tran. assembly. Pls reply
could be a couple things. It could be just that the clutch is not fully DISengaging and barely dragging. In doing so you will have a little drag on the motor even with the clutch depressed (DISengaged) which could cause stumble and low rpm/shaking in the car. However you said wihen you shift and the clutch is engaged the car still shakes -- so either you accidentally said that when you meant be engaged that the pedal was depressed (DISengaged clutch) OR you meant that and the car shakes while in gear with the clutch engaged (pedal upright). Is there more play than before while in gear now? Do the gears actually grind? Have you scoped out obvious things like shift linkage?
