Lurker
- 104
- Sep 13, 2002
I can hear a muffled knocking sound from my car whenever the rpm goes around 3K rpm.
I did a search, and seems like rod knock noise is most pronounced around this rpm range.
However, my knock sensor does not show any activity. Does knock sensor usually pick up noise created by rod knock ? Since the knock sensor does not register anything, does that mean the noise is probably not rod knock, and just probably something loose and resonating ?
It's difficult to pin point the noise. I tried revving at idle, and I can hear it if I'm in the car with the hood closed. But, if I'm outside the car with the hood open, and revving the engine manually on the throttle body, I can't hear anything, because the engine is loud.
What do you guys think ? No knock sensor activity means that it's not rod knock ?
