NO Gauges or guage lights or Turn Signals
mkeclipse98
Mar 21, 2004
Wheeling, West Virginia
I had a problem with the turn signal sometimes not working. I checked the Fuse and it was ok. about 3 days ago they and the hazards stopped working Checked my fuses still no problems.
Yesterday I started up my car and my car idles at 1000rpms, well i turned on my parking lights and the RPM guage dropped to zero So I reset my ECU but it didnt do anything.
Today I went outside to work on it i started the car but my gauges arent working My Dash lights dont work and neither do my turn signals or hazards ?
No Fuses are blown on anything.
So i wondered if maybe my ECU is going bad or my Alternator is going bad?
i dont know if this will help you or not, but it may be worth a try. on my 1g my turn signals didnt work after i did an engine swap. your a 2g so i dont know how much wiring diferences there is. i never plugged my hazard lights button back in when i put my dash back in because the wiring was so short it was a pain to reach so i left unhook. apparently the hazard button has to be hooked up for the turn signals to work. since your hazards are not working also, you may want to check the button to see if connection is loose or a bad connection.
