1990CherryTSI
Banned Member
- 62
- Jan 24, 2004
Austin,
Texas
Is it the ball joint itself? Just the boot? The problem is that we heard a thud sound while slowing down, and now it feels like we are constantly running over a bump. I took off the wheel and on the passenger front rear control arm (what I'm pointing to) where the ball joint meets the arm I was able to push and pull on it and it moves up/down about 1/2 an inch. Is this what is causing the sound? If so is this what is recalled? It's only coming from that corner of the car and the front control arm is solid, I can't move it period. The front rear arm feels like the ball is out/coming out of the socket. Would this cause the noise described above? Second pic #1 shows a bigger pic of the control arm/ball joint/boot. That's where I'm able to move it up and down. Thanks!
