kchaazz
- 1,166
- 80
- Oct 2, 2002
PENSACOLA,
Florida
hey im really upset, i did nothing to this clutch, only launched twice after almost 300 miles of easy in traffic driving to break it in. raced twice after that, drove from grand junction colorado to powers, oregon, and about 400 miles into the trip, i had stopped to get gas and check fluids, took off to leave and bam, slipping clutch. really bad in first, second, not so bad in 3rd, and almost no slip at all in 5th. real sh!@ty if you ask me. hopefully its still under warranty. by the way how hard is it to pull the tranny with the motor still in? just curious cause im doing it tomorrow. anyone have a clue as to why it died? i did everything by the book- torque specs, flywheel stepped to .610, adjusted pedal perfectly- it was not preloaded. i just dont get it. well, anyone?
) and I mean EVERYTHING regarding the clutch in good workign order? If it is then its got to be your clutch. You will eventually figure out how to get your tranny off... even if you have to dropa mtoormount and lower it a little, I have done it numerous times as well and it can be done. When you do let us know if there is any gear oil in teh bell housing or on the clutch at all. Did you check to make sure that your clutch was fully engauging upon release of the pedal?
