dets
- 114
- Mar 11, 2004
Fort Lee,
New Jersey
I have a 90 Eagle Talon TSI 2.0 Turbo.
This car is completely modified for rally cross. I recently began plans to tune the engine a bit more for this season when i ran into a problem. I took out the oil dipstick and it smells like gas. Then the car had a problem cold starting. Compression, pressure, everything was right. I took out the sparks and they were covered in gas. Then i took out the fuel rail and checked the injectors. No leak. I'm going to the auto shop to get a check light for the injectors tommorow to see if they are getting the right voltage. Any suggestions?
