Think I had a surge now I have no reg beam headlights?
SCAMPANELLIE
Nov 20, 2003
I went to start my 95 N/T Talon one day and it wouldent start! Now I know nothing about cars but I knew it was something to do with the battery because nothing worked at all! TOTALY DEAD. So I poped the hood and noticed a cable loose on the batery wiggiled the cable down and tightend it on the batt then tried to start it again and it started but I had a surge and now I only have high beams! Any ideas on what I messed up and how to fix it?
Also I just noticed a rattle in my dash right behind my headunit when ever I accelorate that is really pissing me off..:talon:
First clean the battery terminals and the leads. After that, check your fuses for the low beams, then check the bulbs themselves.
As for the rattling I have it too, (95 Esi) and every other NT I have driven also had it to varying degrees, so i suppose its normal. Just crank your system up & you won't notice it:thumb:
