ECU Swap
sean144
May 4, 2009
West Chester, Pennsylvania
I was wondering if there is anyone that lives somewhat close to west chester, pa (within 40 mile radius) that has a 2g eclipse gst that can meet me to swap ecu's so I can do a few quick runs to see if that solves some problems I am experiencing. This way I can find out if I nned to get another ecu or not.
At idle and starting out from a stop at low rpm my car bogs and almost stalls out. I have already replaced the fuel pump with a walbro 190 lph. The spark plugs semed fine when I pulled them out. I did a boost leak test and the only area I found a leak was somewhere around the fuel rail area, but I have known about that for a while and the car has run fine with that leak before. Also, at higher throttles (from what I have observed about 30% on the AFC) and the boost gets higher which i have set to a max of 15 pounds on an EVO 16G the car sputters and wont give the power it normally would. I removed the ECU the other day and the top didnt realy look bad, but the underside looked like it had adhesive or gunk built up all over the board....I wanted to swap with someone to see if that solves my problem....or if I can eliminate that from the list of possibles. The only other thing I could think of is that over time the leak by the fuel rail area...or maybe the intake gasket has increased to the point where it is casuing all my problems. That is the best I can describe what is going on.
