Compression numbers NOT GOOD LOL
Blaze4G63
191
May 30, 2008
NW, Washington
so i did a compression test yest and i had 130,130,129,130 NOt good LOL car feels really solid though..pulls hard under boost...i dropped some oil in the cylinders and it came up to 175 -200 so i know my rings are gone LOL i got a spare motor but it hasent been ran for over 4 years so who knows what its like...last owner said it was rebuilt but everyone says that LOL
Jeez, how much oil did you dump in the cylinder to bring it up that much?
It's low, but still above the service limit and there isn't much of a variance between the cylinders.
164 psi Standard
121 psi Service limit
14 psi Maximum difference between cylinders
164 psi Standard
like a cap full LOL my shop manual from mits says that service limit is 114 for turbo 90-92 LOL im not happy with where it is but what can u do...i also have 272s though so shouldnt that change the compression numbers? im pretty sure it does...im goin to drop my 720ccs in and do a base tune and see how long she lasts.....if she blows up she blows up im almost expecting it LOL DAM DSM
Do it again with the Throttle open all the way.... bet you'll see a bit better numbers
Also regardless of the condition of you motor adding oil is gonna bump you comp. Numbers as we have recessed dished pistons(low comp) its the high comp. Guys that can get an idea about whether there ring are going out like that....
Fyi if you want a tune thats not gonna blow your motor shoot me a PM....
