turbogixxer
- Dec 27, 2008
Seattl3,
Washington
whats up guys. new to the board and community. i recently purchased a 98 gst. it was all stock with 75k on it. so i had to get some new parts. my mod list:
obx tubular manifold
t3/t4 turbo (size of a 20g)
external wg
3"inch open down pipe
fmic
aeromotive fpr
walbro 255(rewired)
denso 660's
wide band
safc
arp head studs(not installed)
cometic head gastket(not installed)
after all the parts were installed, the car could idle, but i could not drive it. so i let it idle to warm up one day, and it just died. i looked over everything and the fuel pump fuse blew. i put a new one in, and it popped again. so i did it a couple more times to make sure because im an idiot.
. but i figured out that the fuel pump was bad. it was brand new when i bought it.
so i put the stock one in and put back the stock injectors. and the car starts fine, but it doesnt want to drive past like 3 grand. it can barely idle with the safc plugged in, but when i unplug it, it idles fine. my wideband shows that its going way too rich. like 10.2:1 and sometimes even lower at part throttle. idk why its doing that, ### i put back the stock injectors and pump. i set the fuel pressure on the regulator to like 38 at idle.
so i was wondering if anyone had any experience in tuning the safc and could maybe give me a hand. shit... i would even pay for your time if thats what it takes. i just need to get the car running so i can take it to english racing. i live in bellevue are. any input would be appriciated!!! thanks
external wg
fmic
aeromotive fpr
walbro 255(rewired)
denso 660's
wide band
safc
. but i figured out that the fuel pump was bad. it was brand new when i bought it. so i put the stock one in and put back the stock injectors. and the car starts fine, but it doesnt want to drive past like 3 grand. it can barely idle with the safc plugged in, but when i unplug it, it idles fine. my wideband shows that its going way too rich. like 10.2:1 and sometimes even lower at part throttle. idk why its doing that, ### i put back the stock injectors and pump. i set the fuel pressure on the regulator to like 38 at idle.
