renton/kent area please read
lccynmbr13
232
Sep 10, 2006
Renton, Washington
anyone from the kent/renton area have 1 or both of these? i need a repair manual and front motor mount bracket. took my mounts to the shop to get the bushings pressed out and the front one crunched :( have cash if your looking for money, have a smile if it's free :D give me a ring 425-213-2318 ask for jack. thanks for your help!
dont try to press them out. get a hack saw, or a sawzall and cut the metal ring on the outside of the rubber shock absorber (whatever the inside rubber piece is called) The ring is flush with the outer round portion of the mount. Cut the ring through on both sides, but try not to cut into the motor mount very much. If you cut it through it should give the rubber absorber enough room to crush ...and then you can hammer out the rubber inside.
