93GSX4me
- 39
- Oct 30, 2006
Federal Way,
Washington
Ok I have a few ideas but I hate suggest anything to my friend because he's already had the run around from some local shops.... Can you guys help me out . I got a fellow soldier with a DSM on Ft. Lewis thats having issues , here's his message to me :
Well it started with the sputtering and hesitation so i ordered a fuel pump through that site you gave me and took it to a mechanic and he tested it and said that the pressure was good and that it was my spark plug wires so i replaced them and it was still acting up to i went back to that same guy (C&C Japanese Auto Repair) and he said it was my exhaust manifold and so i had it replaced and still problem persisted So once again i went back to him cause he was giving free diagnostics since it wasn't fixed, this time he said it was the air flow meter so i bought one and replaced it! Same shit so i figured this guys was just makin shit up so i went to firestone where they said it was my catalytic converter so i replaced it! Now having spent about 600 dollars and not a damn thing solved firestone says they can't help me! Now it is sputtering and hesitating so bad that i don't even know if i can get it to bridgport to the mechanic and the mitsubishi dealershi, when i stop i can smell lots of unburned fuel and it runs better when the air flow meter is unhooked, when it is unhooked, the boost meter reads that it is pushing max boost when im only at 2000 rpm. Then when ive driven it for anymore than five minutes, when i push in the clutch it drops in rpms so low that it usually dies! I have an 02 sensor but i havnt put it in cause if i do I can't return it if its not the problem, should i try anyways even though firestone says they tested it?
I was just wondering if you had any quick fix ideas that would help me to get it down I-5 to the mechanic. Your help is more appreciated than you know!
Thank you
Thx guys , I really want to help him figure this out and get him back on the road ...
Thank you
