FS: 2G Ecu's 1.Eprom 2.Non-Eprom
DSM_ThuNDeR
565
4
Feb 28, 2008
Salinas, California
Sup guys... I would like to sell these ECU's for my bigger injector funding.:hellyeah: Both are for 95-96, 97-99 will work but the firing order will have to be different in order to work.
1. Eprom ECU - 200
2. Non- Eprom - 50
831-794-seventy FouR zero Eiiight
if you get reflashable one,..... it is gonna be cheaper........
if you get V3, pretty much bay area people can help you out with tuning, but costs twice as reflashable ones.....
So the EPROM ECU means it's from a 95' and has the ability to be changed to accept a chip for a v3. It will work in any 2g. You have to just swap 2 plug wires around thanks to the different firing order. Not to hyjack a thread but I have a 97 ECU if need be
all you do is swap your spark plug wires around, or is you decide to install dsmlink on the eprom... just "invert cas".
I'll see, if my buddy comes through with buying my transfer case on saturday ill probably get it, i'm on a budget sadly, maybe $100 picked up?:)
I forgot to ask, is the EPROM ecu socketed?
