water injection on a daily driver?
1Gina2G
810
2
May 6, 2011
Beaufort, South Carolina
Hey everyone, I didn't see anyone else ask this so, Is it practical to have a water/alcohol injection setup on a daily driver? Or is water injection best saved for the drag cars?
Yup, however whether you actually need it, is dependent upon your setup and future goals.
Look here if you want specific ideas/details/questions:
http://www.dsmtuners.com/forums/nitrous-alcohol-water-injection/256772-ask-your-water-alcohol-injection-questions-here.html
Nothing wrong with using it but once again depends on your setup.
Most people use it to help reduce knock, but as mentioned, it depends on what you are doing.
I dd mine and use meth injection, but that's to combat knock.
Well I have a stock 6 bolt block/ crankshaft with 1g big rods and 2g pistons. stock fuel system for now too. Was just hoping that the water injection setup could add some reliabilty for the extra cooling off, since reliability is my number one priority for this build.
