whiteythepimp
- 92
- Nov 26, 2007
oakdale,
New York
As of right now I ordered a system for post intercooler injection.. I'm strongly thinking about running a second system for pre turbo.. But I want to use a smaller nozzle.. The pre turbo set up I want to run specifically to cool the charge inside the turbo.. But I also want to try to avoid puddling.. I mean if it's an unavoidable situation, I dont mind having to buy a new intercooler core every season..
I've done some research and found out that running pre turbo obviously shortens the life span of the turbo and intercooler.. Hense why people dont run a front mount.. And besides the gains you recieve from either individually compared to the gains you recieve from both, doesnt account dollar for dollar.. Why spend 800 on an FMIC when you turbos life spans gunna be cut in half and you can just save that 800 for another turbo.. Atleast, like i said, this is what I found doing research..
Now with all of that out of the way.. I'm looking to keep the air charge as cool as possible.. Now with the meth post intercooler i'm fine on.. I also want to run a secondary system.. But it's a toss up between pre turbo or direct manifold.. What I mean by direct manifold is.. I have an SBR Intake Mani w/ the nitrous bungs tapped on the underside.. Would it help me to run smaller nozzles directly into the runners there, or go pre turbo?.. Only reason I was thinking about running them through the nitrous ports on the manifold is because im going to be running 35 lbs for d.d... And keeping the internal manifold temps down will help yield my non explosive ending to the manifold.. But by dumping straight meth into the runners of the manifold will it cause internal problems with the motor?... (BTW i'll be running a meth mix of about 75/25 or 80/20 havent tested the yields of either yet..)
What would be the effects of we'll say: (nozzles sizes as per Snow Performance)
running a 60/ml nozzle pre turbo and a 375/ml post intercooler??..
running a 225/ml post intercooler and 4x 60/ml nozzles into the manifold??..
running a 60/ml pre turbo, a 175/ml post intercooler, and 4x 60/ml nozzles into the manifold??..
BTW i'm running a SBR G60, SBR FMIC Race core, Blow Thru set up, SBR Intake Manifold w/ spacer.. Fully built block, Full bolt on besides stock 1g throttle body
