spearco water injection
Bigwilly6754
129
2
May 28, 2002
i was thinking about getting a spearco water injection kit, running it on a switch so on those hott nights before i race i just turn on the switch and go, does anyone no the GOOD and Bad about this or should i not even bother?? thanx every one!
I honestly haven't heard anything good from the kit.. good thing is that's it's relatively cheap at 210 shipped from most places.. thing's i've heard is that the pump doesnt flow enough and the spray pattern isn't that great either, and if i remember correctly the sender starts spraying at 5 lbs which i think is too early
I'm working on a kit now, going to be using a sureflow pump and aquamist nozzles, and a 15psi switch.. i'll let you know what happens with this..
Regis
