99gsthdwcc
- Jan 25, 2005
Cincinnati,
Ohio
quick question, i have some how acquired two 14lb nitrous bottles. my eclipse is a mix of lots of show, and lots of go. To make a long story short i am using an intercooler bar for show purposes and it also has a dual purge valve on it for more show purposes. The setup up was all originally hooked up to one bottle. Could i place the second bottle next to the first and use some sorf of open y valve to connect both bottles at the same time and either use both together or use one till it runs out then just open the valve on the second one? Or would it just be best to separate the intercoolr bar and the purge valves to run off of their own bottle? I just like the look of two bottles in the car......... and yes i know it would be better to just spray it wet into the motor for the best performance.
