can u guys help me out here?
Bd1000Eclipse
Banned Member
756
Nov 3, 2002
I' plan on getting the nitrous express system for my 95 gs. i'm going to start with a 35 shot and end with a 50 to be safe.. i plan on getting an air/fuel guage, and nitrous guage to make sure everything is safe. i hear it will be, but what do you guys really think? will i be ok with this?
I plan on doing the install myself, do you think i can handle it? I have built subwoofer boxes, hooked up amps, my alarm, and but my intake/exhaust on.. so can i handle this? I'm also wondering where to put the bottle? almost my whole hatch is taken up from subwoofers and amps. I have a few little spaces, (the little compartment on the side, and up on the ledge behind the seats i have some space next to my amp. will it be ok to put this stuff so close to my amp and subs? my subs get pretty loud, would this cause any damage to the bottle? i mean explosions, or maybe if something sparks.? so tell me what u guys think.. thanks
Nitrous is a good method of making more power, you should be fine. No stereo is gonna hurt that bottle.
The kit turns on depending on how you wire it. You could do a WOT switch and a switch on the dash so then it would only spray when the switch on the dash is in the on position and when the WOT switch is pressed. You could also do a momentary so the nitrous only spray when a button is pressed (think F&F).
