DavidGST
- 57
- Jun 7, 2003
Central America
hi guy's
recently i ordered a crankshaft kit from flatlander racing for $425
for my 1995 eclipse GST...
when i got it it won;t fit..when the mechanic turned the crankshaft by hand it was grinding on the rod and rod bearings..
so we took it out measure the rod jewel ant it's 44mm
ok i put the new connecting rod with the bearings i ordered on the rod and it's very stif you cannot even turn it with the hand..
so i e-mail flatlanders telling them to check if they send me the correct one ,,,and here are the mails i got from them ..
We contacted the warehouse and you have recieved a csmi6 crank just lkie you
ordered,they are for the 4g62 92 and up motor including the turbo,you might
want to check out what you have.Do you have the correct block?
Thanks,
Phil
Tech Dept.
Flatlander Racing
603-378-0090
ok aren't the 92-94 eclipse 1 gen and 6 bolt crank?
95-99 2 gen and 7 bolt block?
i mailed them back and told them this info and here is what they send me
Look on our web site........All 4g63 motors after 93 including the turbo take
the same crank,the one you ordered mi6.
Thanks,
Phil
Tech Dept.
Flatlander Racing
603-378-0090
please tel me what i have to do because they think they sold me the correct crank...on the website they have the same crank too for the 92 till 98 eclipse...
Thanks
Daniel
Thanks,
Phil
Tech Dept.
Flatlander Racing
603-378-0090
Thanks,
Phil
Tech Dept.
Flatlander Racing
603-378-0090
Thanks
Daniel
