coolant leak by oil filter??
xcelr8n
1,854
5
Jan 31, 2003
toronto,
i changed my oil tonight, and there is this line that comes out of what appears to be the oil filter housing, and runs upwards. I had to adjust it slightly to replace the filter, and now it leaks coolant at a slow but steady pace. it has two clamps attached to it, the uppermost clamp came loose i tightened it as best i could and it still drips.
what does this line do? how can i fix it?
thanks alot
Are you sure that's where the coolant is coming from? If so, just replace that line, it's just a coolant line running through the oil cooler. Go to auto store and pick up a foot of coolant hose(3/8 ID if I remember right) and replace both lines while you are down there.
the car has 180,000 miles
timing belt and water pump have about 12,000miles on them. The reason i dont think it is the wp is because it wasnt leaking before but i adjust the hose a little to get at the oil filter and it start to slowly drip and i cant seem to tighten it.
if i just pop of this hose, will coolant pour out uncontrollably??
That is what I think is going on also. You may notice that once one coolant hose goes all of them start to go. That is what happened to me anyways.
I would take some time and go through and replace them all at once instead of doing them whenever they break ;)
