13g-14b turbo conversion
Status
Not open for further replies.
Eliminat0r
1,385
2
Jun 18, 2003
Clinton Township, Michigan
just scored a deal from someone hes gonna give me the 14b turbo, exhaust manifold, injectors, oil lines, gaskets, coolant lines, banjo bolts, crush washers, and turbo inlet gasket. is this all i need to put a upgrade from a 13g to a 14b on an automatic trans talon. hes also giving me boost controller and gauge for an extra 50.
o one more thing anyone in the S.E michigan area know where i can go to get the turbo installed.
Thanks
nobody knows
geez i listed everything he was giving me and i was very specific bout details
cmon someone help me out here i know im not the only one who has or had a 1st gen dsm auto trans
Sounds like you will have everything you'll need.. Just make sure you get NEW gaskets, and crush washers!!!! If the guy giving you the turbo says the gaskets are only slightly used DON'T use them.. For the few dollars it will cost to get new ones do it... I just upgraded to a Big 16G from a 13g on my 91 auto GSX. I used the old gaskets for the oil return line (I was told they were only 2500 miles old).. Well, they leak, not badly but enough that i can smell fresh burning oil that gets blown onto the downpipe when i roll up to a stop light.. I ordered new gaskets from the dealership for about $1.25 ea. Im going to install them at my next oil change since removing the oil return line would dump most of the oil from my pan anyway...
IMHO, just get NEW gaskets and washers to be sure...
Brad
PS. find a shop local to you that works on VW's and Porcha's (sp.) they will have some turbo exp.
cool you know how much it will cost to get it installed
Status
