Parking Brake Warning Light Won't Shut Off
4Bangin
32
Dec 31, 2002
My Parking Brake Light won't shut off, when I put the parking brake down it dims a little but won't shut off, brake fluid is fine, even the plastic thing inside the brake resevoir cap is in the right position, is there any other sensors or anything that would cause the light to stay on?
First, parking brakes are cable, not hydraulic, so yer master cylinder has nothing to do with the problem. The most likely source is a fried switch, but if I were you I would ignore it, as there is no point for that light in the first place.
Hmm. Sorry. I had read in the owner's manual that this particular idiot light was only for the e-brake... Guess I was wrong. :D
