stock turbo limits
Geoff
Jun 28, 2003
i understand that the stock 2g turbos are smaller and can only efficiantly support about 15 psi. My question is, about how fast would that put yuo in the 1/4 mile? Assuming fuel needs are met for the added boost, but with really no other major mods.....how much faster would it be? I realize that withought a highflowing ehaust spool up rate will be decreased. And im talking 2g awd talon btw. I also know it depends on the diver so whats a rough estemate?
theres lots of variables, to find out that fastest t-25 go to dsmtimes.org
it all really depends on what mods you use on your car and how you mod your car based on your "goal", set a goal you think you can get and can aford then go to the "tuning guides" and start thare and base what you buy on how much it will limit you. So if you want to run mid 12's and it won't hurt you to go buy all the supporting mods needed to run 12's and with t-25 yes it will be a big set back but it will be saving you money in the long run instead of buying another turbo to be replaced with a bigger one in the long run.
but its kinda hard to answer exatly what your saying if you don't have a list of mods for the car. but follow the tuning guides and they should help give you an idea
