Naked Guy
- May 9, 2003
Under normal operation, when the top is closing or opening (with your finger still on the open/close button), the motors will stop when the top is finished moving.
A while back, my convertible top motors started acting strange - the motors would continue to run when I continued to hold the button to operate it. This happened about a year ago.
Now, the motors are not strong enough to operate the top anymore. I can open and close the roof manually, and everything is moving the way it should. The motors still try to turn when I try to open or close the top electrically. The only time the motors are strong enough to move the top is when I manually open it halfway. Since the motors are no longer trying to fight gravity, they can open or close the top from this position.
I checked the voltage to each motor, and it is as it should be. When I take the motors off the car (keeping the electrical connectors plugged in), they turn as they should.
How can I test the motors to see how much torque they turn with? I'm guessing only one of the two motors isn't doing it's share of the work, and I don't want to have to replace both if I don't have to.
Also, what would cause the motors to continue to run, when they should shut themselves off when the open/close motion is finished? Would this have anything to do with my weakened motors?
Any help you have is appreciated.
