1g BOV...How do I install on my 2g?
if you have the arapter you just bolt the 1g bov to it, remove the hose clamp holding yer 2g bov to your upper innercooler pipe, yank it out , and put the new setup it and replace the clamp
I already have it on, along with my Brode Upper IC pipe. Thanks
Did you seal the area between the two? You really should. Weather its a gasket or silocone from the hard wear store.
