door light sensors
ForsakenLash
Proven Member
156
Mar 15, 2013
Jacksonville, Florida
My door open buttons are messed up, they dont read when the doors are open. if I wiggle them around they sometimes work, it feels like the button its self is broken on both driver and passenger side. How can I fix these?
I've tried to get them before from O'reilly but they were non stocked in any nearby warehouses and also special order only. So I purchased mine from ebay not to long ago. Here are an couple different makers and part #. Simple to install just remove the one screw, disconnect old one and replace.
Airtex 1S4784
BWD S1016
ACDelco C6038
Standard Motor Products DS1653
Or go to a junkyard and get them for free. If there are no eclipses there then look for avengers or seabrings
I tore mine apart and cleaned the parts with contact cleaner. Reassembled with dielectric grease and they've been working fine for the last 5 years.
may have to try this... the problem is it feels like they are broken inside the rubber housing. its rather annoying
