pureinsanity
- Feb 8, 2011
bellvernion,
Pennsylvania
I recently installed a megasquirt into my 420a Talon. (This is the kit I got Complete 420A/Neon MegaSquirt EMS Kit - SymTech Laboratories ) For some reason I am not getting any spark. Also the rpm gauge on TunerStudio is not moving at all. The only gauge thats showing any life is the fuel load wich is at 98%, and the AFR guage is at about 17. The coil pack is getting the normal voltage to the center wire on the plug (R/B). The Crankshaft posistion sensor is getting about 4Volts and the 5V VREF wire is getting about 0.4Volts. Also I have no led's lighting up on my Megasquirt I would normaly try to trouble shoot my issues before posting them on here but it started raining and I never messed with a stand alone ECU before. So before I mess something up I decided to check wit you guys!
heres the wire diagram I used. ( http://www.symtechlabs.com/support/docs/MS_Wiring_Guide_420A.png )
