What's missing on my 1G TB? (Pic)
High PSI
145
17
Oct 21, 2004
USA, Australia
I just picked up a 1G TB for my 2G and noticed that one of the sensors (below the throttle plate, to the left - I'm guessing it has to do with the FIAV) is missing.
Can I swap over the one from my 2G TB? I would like to keep the FIAV for now as I plan on using the car for the occasional snowboard trip.
That's your idle air control valve. There's two screws on the sides to remove it . Looks like someone took if the top portion only. Yes you can swap in a 2g one.
You are missing the upper half of the ISC motor. There are 3 screws that hold the upper half of it to the bottom half. If you take off the other two 8mm bolts(they have a phillips on them too), then the lower half will come off.
Here is a neat "how to test the isc" link that will give you a good picture as well as info to test them.
I am unfortunately unsure if a 2g isc motor will work. I can tell you that any 2.0L 1g motor will work(turbo or non). The 1.8l will not work.
