horizontalkev
Supporting VIP
- 1,000
- 2
- Jun 28, 2010
great bend,
Kansas
Two questions:
1. Who has used the Android Application "Torque," is it worth it and is it accurate? Just ordered my OBD port bluetooth for it.
2. My clutch pedal, when I bought my car it wasn't driven for 5+ years and when I recieved the car the clutch pedal was either stuck pushed in or out, just popped back and fourth without pressure, after flopping it back and fourth 20 times it gained a little pressure. More I kept doing that the stiffer it became. Now its no longer getting any stiffer, is just stiff enough I can get into gear, but just loose enough where it can be hard to quickly shift to the next gear. A lot of the time I have to press the clutch in several times to get a gear in easily, otherwise im almost forcing the gear in. Is my slave cylinder bad? Maybe just a matter of bleeding the lines? I didnt have to add any DOT3 fluid. Probably needs to be chamged out though.
