2g jays racing & electro p steering
dskagr
46
46
Feb 7, 2011
209/408, California
I have the 2g jays racing alternator kit, and plan to run an electro power steering from an mr2 instead of our stock one. In this case, I don't know which belts go to where. The alternator to crank would work fine, but then what about the water pump to crank? Could I get a long enough belt to just use one all the way around the inner most spines using the small pulley or use the bigger pulley on the water pump and get a small belt straight to the outer spines on the crank? Any help would be greatly appreciated. Thanks!
