Login
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Welcome to DSMtuners
Newbie Forum: Beginner/newbie/general DSM modification questions. First mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. Probationary Members must limit their tech posts to this forum and sub-forums.
Reply
LinkBack   Thread Tools
Old 07-21-2012, 10:45 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
gameover95's Avatar
Tech Posts: 60
Photos: 10
Classifieds Rating: 0
Reputation: gameover95 is an unknown
1995 Eclipse Gs-t oil pan gasket change
Just trying to clear this up.
The oil pan on the Gs-t is just simply removing the bolts and lowering the pan out of the car(after draining oil) correct?
Thank you.
View photos of this member's car
mark post as helpful recommend reputation points    Reply With Quote
Old 07-21-2012, 11:04 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
fourgsixthree33's Avatar
Tech Posts: 868
Photos: 14
Classifieds Rating: 8
Reputation: fourgsixthree33 is an unknown
Send a message via AIM to fourgsixthree33 Send a message via Yahoo to fourgsixthree33
No, you have to remove the support beam as well. And may have to drop the exhaust from the downpipe.
Be lucky you don't have an Automatic 1G AWD. Support beam, exhaust, driver side axle, and some other stuff needs removed.
____________________________
95' TSi 7 Bolt 14B
Daily Driven
AJ
Visit fourgsixthree33's homepage!  View photos of this member's car
Old 07-21-2012, 11:07 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
DSM Wiseman
bryanwheat's Avatar
Tech Posts: 5,761
Classified Ads: 1
Classifieds Rating: 35
Send a message via AIM to bryanwheat
Also to properly seal the pan you don't use a gasket you will want to use a bead of grey rtv to seal it.
Old 07-22-2012, 12:20 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
DSM Wiseman
WES_393's Avatar
Tech Posts: 2,447
Photos: 13
Classifieds Rating: 6
I've never had to drop the support beam. Just the exhaust, driver axle carrier bearing, and maybe some other random stuff. I second using only a bead of RTV.
Also keep track of the two shorter bolts that go into the timing cover.
-Wes M
16g/E85- 12.7@108
H1E/E85- 13.2@105
Old 07-22-2012, 12:32 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
NHerron's Avatar
Tech Posts: 2,031
Photos: 3
Classified Ads: 1
Classifieds Rating: 10
Reputation: NHerron is pretty helpful and trustworthyNHerron is pretty helpful and trustworthy
There are two specific bolts to keep track of, which the picture attached outlines. Otherwise the correct length bolts may be mixed up with longer ones and cause damage to the timing belt in a groove like way. The picture also recommends RTV to be used as already stated. The oil drain for the turbo which attaches to pan uses crush type washers under the bolt heads.
Click image for larger version
Nathan
Car's built on the inside, but not out :)
Old 07-22-2012, 07:57 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
gameover95's Avatar
Tech Posts: 60
Photos: 10
Thanks again guys, this will hopefully be a successful afternoon lol
Old 07-22-2012, 07:59 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Proven Member
re-rx7's Avatar
Tech Posts: 316
Reputation: re-rx7 is an unknown
Another good RTV is made by Porsche. Pricey but has never let me down.
Old 07-22-2012, 08:13 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
Proven Member
gameover95's Avatar
Tech Posts: 60
Photos: 10
I have a straight shot at the oil pan, which support beam are you speaking of?
Old 07-22-2012, 08:36 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Proven Member
ec17pse's Avatar
Tech Posts: 892
Photos: 6
Classifieds Rating: 4
Reputation: ec17pse is an unknown
He means the beam that the front engine mount is on, this you dont have to do but the down pipe is a must! I used the gasket jnztuning sent me which is cork and ive not had any leaks and i did that about a year ago now. Rtv is still ok to use, i just prefered a gasket as its better to get off again and seals 100% where you might miss a section on the rtv,
Either way its upto you, only the DP and gearbox inspection cover needs to be moved and NOTHING else
BOBBY
DSM is to move to Tampa Bay
Old 07-22-2012, 08:48 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
DJChunter's Avatar
Car: Colt
Tech Posts: 8
Reputation: DJChunter is an unknown
The Best RTV I have used is made by toyota and is FIPG, you want the motor stuff (Black) but they also make a trans one thats (pink) and stays a Little softer.
Dave
Old 07-22-2012, 08:48 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #11 (permalink)
Proven Member
Tech Posts: 868
Photos: 14
Yep, the support beam under the car that runs from the front engine mount to the rear of the engine and attaches to the sub-frame.
I had to remove this on mine. Maybe I didn't HAVE to but it made it easier. If you remove this, the triangular support piece near the right front wheel needs removed as well.
95' TSi 7 Bolt 14B
Daily Driven
AJ
Old 07-22-2012, 09:55 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #12 (permalink)
Proven Member
SpiderGST's Avatar
Tech Posts: 222
Reputation: SpiderGST is an unknown
Quote:
Thank you for the diagram. I will be using it during assembly of my motor.
Maxwell H.
97 GST
95 TSI
2000 S10 2Dr. Blazer
Old 07-22-2012, 11:13 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #13 (permalink)
Proven Member
ec17pse's Avatar
Tech Posts: 892
Photos: 6
no you really dont need to remove them lol it was NOT tight for me or a pain and i was on the floor aswell, im not sure i follow on this triangular piece as i never took anything off but the DP and gearbox inspection cover and i did the whole job with only them items off, maybe if you can link me a pic of what you mean just for reference,
BOBBY
Old 07-22-2012, 11:40 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #14 (permalink)
Proven Member
GSTurbo1's Avatar
Tech Posts: 558
Photos: 35
Reputation: GSTurbo1 is an unknown
Can you not use the red rtv?
1990 TSI AWD... My first 4g63 :)
Old 07-22-2012, 11:41 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #15 (permalink)
DSM Wiseman
bryanwheat's Avatar
Tech Posts: 5,761
Classified Ads: 1
Quote:
You could, but it is probably the worst type of rtv that you can use. Grey is a way better choice.
Reply
Bookmarks
Thread Tools
» Recent DSM Videos
1gb AEM wastegate hood dump 2step
» Recent DSM Photo
Post your banner here
» Current Poll
How many times have you been to the Shootout?
1 - 38.41%
111 Votes
2-5 - 43.60%
126 Votes
6-10 - 10.73%
31 Votes
11-15 - 2.77%
8 Votes
16-20 - 4.50%
13 Votes
Total Votes: 289
You may not vote on this poll.
» Online Users: 871
346 members and 525 guests
Most users ever online was 1,704, 03-17-2008 at 09:11 PM.
DSMtuners Main Sections
DSM Forums
DSM Regional Forums
DSM Builds/Journals
DSM Articles
DSM Tech Guides
DSM Upgrade Paths
DSM Parts Reviews
DSM Vendor Reviews
DSM Classifieds
DSM Parts Guides
DSM Photos
DSM Videos
DSM Timeslips
DSM Dyno Sheets
Shirts & Apparel
DSMtuners Decals
Advertising Info
Our Sponsors
Site Rules
Terms of Service
Privacy Policy
Site FAQ
About Us
Contact Us
