Quote:
Originally Posted by bryanwheat
Pull the valve covers and check for play in the rockers. Are you using a high zinc oil for the flat tappet cam or just something random? It is possible that you have a rod bearing problem also. You will never know until you check it out though.
That is the fist step I will take, and yes I am using a high zinc oil by Lucas. seems to have power but it does miss a little. Thanks though
There is no tension adjuster on a v8 like this. The chain goes over the gears, you slide the gear on the cam and bolt it on. The chain would have to be very very stretched to make any kind of noise.
Thaks and your right there is no adjustment on the chain and gears. doubt the chain is stretched in 25 miles.
will start at the top and work my way down and see whats up.
Quote:
Originally Posted by wrencher
Not really the right forum.
But this is funny I had a customer that did the same thing on a Mustang.
Rebuilt the OE motor & it started ticking. Then it just got louder & louder.
Then it was a knock.
It was a tought one to figure out, but it was the pistons he used.
You would be suprised even quality names you know have lower product lines that are on the cheap.
But doing some research small block fords seem to be having this issue here & there.
thanks , the pistons are stock as well as everything but the cam, and the pistons haven't been out just changed the bearings.
Quote:
Originally Posted by 1gAWDlaser
I'm not so sure you will find your answer here being it is FORD. This is a DSM site. Is there no ford website for you to get help on this subject?
Just stumbled upon this site when I put in for ford it sent me here and its not telling me it was for your type cars in the beginning....do you know of a ford website that has a help thread like this....we all have the same pricipal in mind. Thanks
