Help identify this BOV
94lt1
Sep 18, 2011
Wheaton, Illinois
Can anyone give me any info on this BOV? I'd search for it myself, but theres no part #
It's an old school spring based bov.It should come with 2 springs.No idea on the part number.
If you twist the top off there shall be the spring, then the piston, and a snap ring that holds the piston from coming out.
RFLs have a horn. That's a Type H.
Still fluffing that post count, eh Bud?
I thought we were done with this back and forth thing..Anyway no.
I happen to have a blue one of these I bought from a 2g guy some years ago..
I would also be happy to be reset back to 0.But since that's not an option.I think I would rather go forward with the correct information..I have made enough mistakes..And it's because of people like you, that I have learned form them(I hope) and even learned a thing or two..
So I hope to not make mistakes.But making mistakes and being punished is how you(ME) will learn.
So please, can we just go forward?
Consider it done.But dont forget if im kinda off on the answer trying to asnwer the best i can. Holding my hand would be nice. I have much to learn. But im gonna make a real effort this time not to mess around. Jokes are still fair game.
Im on my phone. So no auto capitalization. Fixed now.
We don't have one, but if we did, my posts would overload the SQL back end, anyway. ;)
Back to the BOV? ;)
If it were up to me, I'd ditch that one and get a turbo xs rfl. Sounds amazing trust me you won't be disappointed.
Except for the fact that you can't recirculate either bov. Buying a blow off valve for the sound it not smart. The function and efficiency of the bov is the most important thing. A dodge garage modded 1g bov would be more than sufficient for most people.
Either way these BOV's leak, A LOT!!
or i havent been lucky with them :p
I have experienced the same. They don't hold pressure well. The piston is the same diameter on the top as it is the bottom so there is no way for it to be held closed under boost. The spring is the only thing holding it because of that. A properly designed bov will have a more surface area on the upper part of the piston or diaphragm than the lower so that it can be held closed by the pressure in the bov line.
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
  • For sale 420A 420a heat shield
    $20 and free shipping. Need gone
    • Stizzydrew
  • For sale 420A 420a parts
    Stock Cam caps, lifters, rockers.
    • Stizzydrew
  • For sale 420A Stock 420a camshaft & cam gear
    Stock 420a camshaft and cam gears. $100 + shipping or best offer. I no longer will be using 420a...
    • Stizzydrew
