TheWanderer
- 149
- Oct 26, 2007
Reading,
Pennsylvania
I went to check out a 92 TSI FWD tonight that I want to buy. Has a bunch of mods done already (16g, large FMIC, new aluminum radiator, 550cc injectors, 2.5" hard piping, greddy BOV, 3" MAF, 190lph walbro), and is running what I'm told is 14psi boost on an ebay MBC. Recently had a new timing belt installed.
Its a nice car overall, but I have some concerns and questions:
The car is running rich, that much I know. The current owner has a 3" MAF without a translator installed, so I know it will need that for certain. I have a feeling it also needs new plugs and wires. Also needs an intake and exhaust done to finish up stage 1 and 2 mods.
The car sat for about 4 years, and the current owner recently dropped the tank and drained the old gas, filling it with about 5 gallons of 93.
Now here's the tricky part:
Its hard to start, cranks slow, and dies. Once it does start and run (about the 3rd try), it idles fine. As soon as I step on the gas, it stumbles/sputters and dies. The stumble clears up around 2k. At first when i started it, it acted like it had a miss or dead cylinder as I got on the gas, all the while sputtering. It came to a point where I had to actually double step the gas and brake while holding at 2k to 2500 rpm and slipping the clutch to get it moving. It pulled about 25psi vaccuum at idle on the aftermarket boost gauge, and from what I understand, that is normal.
Once it warmed up, it ran a bit better. Still stumbled and sputtered until about 2k rpm though. So I took it for a ride, and it still hesitated, then all of the sudden it kicked into boost around 3k-4k rpm, and BAM! knocked me back in my seat (which I loved by the way
I looked back in my mirror and saw a trail of bluish white smoke, a heavy cloud of it at that, for about a 1/4 mile up the road behind me. This has me worried.
Could the smoke be a bad head gasket? I didn't see any coolant in the oil or oil in the coolant. Car wasn't overheating at all, so I don't know what would be causing this.
I did unplug the stock MAF, and the idle dropped a bit, but the car didnt want to die when you got on the gas once the MAF was unplugged. Seems like it could partially be a bad MAF (it was a junkyard maf from what the owner told me, recently put in).
I did read something about this possibly being a bad turbo as well? Something about the seals being shot? Any thoughts? It seems unlikely considering the turbo only has about 4k miles on it (or so I'm told). Not sure if its a real 16g or an Ebay one though, and from what I understand the Ebay ones are junk and are known for this kind of stuff?
I plan to go back Saturday with the logger and see what I can pull up.. Also going to try and get my hands on a loaner MAF Translator and see if I can't lean it out a bit, at least enough to drive it. Has a few other minor issues that need to be addressed as well before I can drive it. The intake side PCV hose needs capped, the new electric fans need hooked up to power, and some other minor items. Also planning on doing a compression test and leakdown test to see what I come up with. As for boost leaks, everything looks pretty tight, and all of the hard piping has been sealed with rubber cement at the couplers (why?
Any info you guys can provide is much appreciated. He wants $1800 for the car, but I can't see spending that much as it sits honestly, and I can most likely get it cheaper. Any thoughts on what to offer? I was thinking somewhere around a grand myself...
)I looked back in my mirror and saw a trail of bluish white smoke, a heavy cloud of it at that, for about a 1/4 mile up the road behind me. This has me worried.
)Any info you guys can provide is much appreciated. He wants $1800 for the car, but I can't see spending that much as it sits honestly, and I can most likely get it cheaper. Any thoughts on what to offer? I was thinking somewhere around a grand myself...
Wouldn't surprise me one bit if it is, considering these cars tend to be a beast of their own when it comes to timing, and not many mechanics (outside of the dealership and straight up DSM mech's) know how to time the car properly...the car shook like a tank the first 2-3 times I revved it up after I started it the first time. My 3kgt VR4 did the same thing and wouldnt fire (turned out to be timing AND a fragged piston from detonation)...
The wiper arms need repainted (like every DSM I see around here it seems). Front bumper has paint flaking on the driver side because some idiot with a roll back couldn't load or unload the car right
) but it smoked when it started getting in boost. The strange thing about your situation is that it still reading good vacuum which timing, bottom end problems, or a headgasket would more than likely affect. The sputtering more than likely is the 550's with no tuning. Compression test should answer your smoking problem. If its the turbo your aren't too far from blouch turbo for a rebuild. As far as price goes the shell looks to be in exceptional condition but pending a compression test I wouldn't spend more than $1200-$1500 but see what the guy will take.
Hoping to go pick it up tonight or early tomorrow morning. Saves me $10 for shipping
Any ideas?
