Mo95Talon
- 85
- Aug 1, 2004
Dexter,
Missouri
Alright fellas I need help. Two weeks ago I install a new exedy oe replacement clutch. Went fine car ran great. After having to put a gallon of coolant in my car every day I decided to change the water pump at the the same time also decided to change the timing belt and balance shaft belt. I live in a little town with mechanics that only like working on "american muscle". I followed the vfaq got all timing mark lined up correctly replaced timing belt, balance shaft belt, all new pulleys, and water pump. I took the car for a test drive and ran awesome. I was proud of myself. After about 2 miles the car went into a stumble and threw a p0300 code and felt like it was only running on two cylinders. I pulled the car over to the side of the road, turned the car off check a few things under the hood. Started it back up and ran like it was brand new. Drove another mile or so stumbled again and started missing again. Any ideas? I looked through the forums and saw alot of p0300 codes but most of them ran like bad all the time. Mine runs great then goes into a tizzy until you turn it off then back on... Hope someone has an idea. Thanks for your time.
